Fans for Lian Li PC-V2100
ohnnyj
I have one of the Lian LI PC-V2100 cases and it comes with two 120mm fans already but I want to cool the inside of the case even more as I have two 6800GTs and an FX-55 in there that can make it get pretty hot when loaded. I have a pic here that shows the back of the case and there are two places (see third pic from the top) that have what look to be places for fans (just above where the PSU sits on the bottom). Would placing some smaller fans here help at all? Anyone know what size they should be? Any other helpful ideas on how to keep thing cool w/o voiding warranty (i.e. no water cooling, although I really wish I could)?
Thanks.
voiding what warrenty? Go watercooling w/o hacking your case up if you want. Whos to safe a cpu burned out from improper seating of a cpu waterblock opposed to the regular cpu heatsink lol.
stick with 120mm fans if u can best noise vs airflow.
Removing stock cooling from the video cards and/or the CPU will void the warranty, that is what I was talking about.
