fans and electrical stuff
lukeh182
is it possible to run 8 fans with and LED and switch hooked to each fan with ONE 12v line from my computer? or will i need to use multiple lines?
It should be, but it depends on the fans, for example if they were ventec tornados, no. Add up how many watts wach draws and look at the max wattage per line on your PSU. Give yourself about 10-20% extra just in case.
