Hello! Planning a new build with the Rosewill W1 Mini ITX case:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147221
I was hoping I could use a Seasonic Platinum 400 or 460W FANLESS PSU with this case.
PSU: http://www.amazon.com/SeaSonic-SS-4...74&sr=8-4&keywords=Seasonic+Platinum+Seasonic
I'm a little concerned that the closed-off motherboard plate directly above it will not allow for enough passive cooling for this PSU. There are slits on the back and an opening directly under the PSU for it to breath that way.
Does anyone have any thoughts on whether this will work? Or should I consider something with a fan?
