Fanless AIW Cards
Sib
I am replacing my secondary computer with a Shuttle XPC SFF case. I also decicded that I might as well get an AIW to do some video capturing. My question is if anyone knows of a 9600 or better that is fanless?
Also does anyone know if the X600 AIW will come out in a AGP format?
They did. It's called the 9600XT AIW. Really, the x600 core is basically the 9600 in PCI-E form.
The AIW isnt fanless, and I dont think theres enough room in a shuttle for that zalman heatpipe. The fan it comes with should be quiet enough though.
Same GPU Chip but the X600 boosts newer Features for TV out and what not.
The Newer AIW chips allow for better recording (less CPU load and what not).
You know if that card has Hardware Divx encoding?
I think the 9600 has two versions. The old version with fan and the new one without fan. I think the one at newegg is the new one. To bad I can not order from a cheaper place, because I have no idea what I would get.
