FANBUS?
I'm looking for a good fanbus that could control my fans.
-- optional temp speed controlled,
-- optional lcd output.
about my setup:
I have a big case that used to house a DELL XPS630... Now I just have the case with a new pc upgrade in it.
In that case where two huge fans 120mm fan about 1.5 inch deep they are both 4 pin fan and I think they are PWM fans
My new vid card a HD6970 being quite long actually split the insides of my case in two zones, one for each of those fans.
at the bottom I have a fan that pushes air through 4 hdd, then this air goes to the CPU then it exits out the rear.
up top, I got my fan that pushes air on top of my vidcard (which as 3 fans) then the air is exited out the rear
My idea, with temp prob would be to monitor the temp in each zone and make sure everything is not too hot or increase the speed.
Both the CPU and GPU have temp controlled fans.​
thank you for your time.
