Fan tails?!?
Dekar12
Alright, I guess I screwed up when I was ordering Panaflow fans from Frozencpu and I didnt notice that they needed tails added to the fans.
So, I have 2 fans sitting here with just wires running out of the fan. I don't have any fans I can scavenge the 3 pin conectors from so I dont know what to do.
They have the rpm sensor which I want to use so I cant just solder them into a 4 pin molex to use them. Anyone have any ideas or a place I can buy some 3pin connectors.
I looked on Frozencpu's site and they don't have any fan tails for sale
I can get the ends for them, but they don't come with the little metal connectors that are suppose to be connected to the wires. If you look at a plug running off a fan there are little metal connectors similar to a molex. Its those that I am lacking. I jus thave bare wires
Jima,
Thanks those are exactly what I was looking for.
I think im gonna just get the ends, since I have the wires and that kit comes with the metal parts.
Again, Thanks ;)
glad to assist...
I've tailed many of those panaflos I bought from Joe Awe.... :)
I have a similar problem but I have Delta fans with no metal connectors. I have 3 pin connectors but not the metal connectors. Can you buy those from a hardware store? If so, where?
