MysticalOrca
- Dec 2, 2013
Awhile ago I impulsively purchased this item (http://www.amazon.com/Phobya-4-Pin-3-Pin-Splitter-Connection/dp/B007S3T4O0) to aid fan cabling issues and for that it has worked great, I plug them in at one place and they work. But I never realized that there would be a lack of rpm control and it is really beginning to bug me. I know you can switch some molex wires to get a 7v mod which is what I would really like to do but I am no electrician so I want to be safe.
The setup would be this: PSU w/ modular molex cable -> fan splitter -> same molex cable -> d5 pump. I might be able to plug in a seperate psu molex cable for the pump if that is needed. And like I said, I am stupid with electricity so if it isn't possible just tell me
Thanks in advance for any input!
P.S. I debated whether to place this here or in the Power Supply section, if I was wrong please move it
