fan speed controller question
i plan on buying this fan controller, and i was wondering if i could hook up 2 fans to it using some splitters. if so, will they run at the same speed? thats what i want. or will the 2 fans need more power than the controller can give them? thanks.
Don't think that is hard enuf for DIY.
Ive build two 75 watt PWM regulators for the two 120mm Delta's.
*PWM is pulse width modulation, ofcourse a fan would make funny noises when you''d give it actualy PWM signals its Filtered through an L-C circuit.
*95% efficency. @ +/- 8 volt out. 12 v in.
2.31 A in
2.22 A out .
:cool:
