I have been noticing that my CPU in my main machine had been running a little hotter than i would expect with the temperature dropping outside and it generally being cooler in the house.
So the V8 Cooler Master I have is only getting up to like 400 RPMs ever. Fan is shot for whatever reason. I need to pull the cooler off the motherboard or figure out how to detach it without removal.
Before I get into that, I want to have a fan replacement on hand that will get the job done. A lot of the fans are rated as "case fans" damn near everywhere I look. And I've been trying to find the CFM ratings on these things, but have to delve into the specs on the various websites at their different "turbo"/"quiet"/"max"/"whatever".
So basically, I know I need:
1) Something that will fit in the cooler. It APPEARS to be a 120mm x 120mm x 25mm fan in there now. I am hoping someone has some experience and can tell me what they've had luck with on replacements.
2) I need a CFM above 65. It looks like the fan that came with it was rated at high 60s according to their website.
I don't care if I eliminate the knob on the cooler, I personally don't use it. I'm guessing PWM will be useful for noise and longevity. I don't particularly care about noise as long as it isn't rattling or high pitched/whining. Longevity would be nice.
So........hoping I can get some quick replacement suggestions so I can order something tomorrow and get my main machine up and running again. Massive PITA removing the heatsink to replace the fan, so I would like to not have to do this again for awhile.
