Fan Recommendations?
JKownz
I am soon planing to buy a Corsair 800D and watercool it with a 360 radiator and change out some of the fans. What is the best performance fans for the radiator and case that i should get? 120x25mm? or 120x38mm? . I know i can always get a fan controller if things get way to loud. But i don't want fans that reach 170+CFM and 70+dBA and make my computer sound like a hurricane all the time even on lowest settings on the fan controller. My gaming area is relatively small and my case is not to far from me. Any suggestions on optimal performance while not loosing my ear drums?. Any suggestions/experience will be greatly appreciated. :p
Gentle Typhoon 1850's.
http://www.newegg.com/Product/Produ...2&cm_re=gentle_typhoon-_-35-185-092-_-Product
http://www.amazon.com/Scythe-Gentle...1?ie=UTF8&s=electronics&qid=1274418376&sr=8-1
I'll probably get flamed for even recommending these (by people who have never even used them), but I went from GT's to Gelid Wing LED PWM fans. They give me about the same temps and noise (minimal), and I'd highly recommend them IF you want PWM fans.
http://www.performance-pcs.com/cata...oduct_info&cPath=36_407_696&products_id=27555
http://www.performance-pcs.com/cata...oduct_info&cPath=36_407_696&products_id=27554
I don't usually bother with PWM fans, voltage fan controllers usually work just as well, not to mention being much more common. The Gentle Typhoon 1850's lowered to about 1200 RPM are virtually impossible to hear unless you put your ear right to them from what I've heard. At full speed, they're audible, but somewhat barely. They also have pretty good pressure, so they don't lose as much air movement through high FPI radiators as other fans that have low pressure (the Scythe Slipstream fans is one such example; high air movement, but drastically reduced due to low pressure).
I don't have a set of GTs here (rather some Phobya fans someone sponsored me, and some other powerful fans), but from what I've heard, they're dead silent at certain speeds, and even at full blast, the sound they make is a very neglectable hum. Perhaps that's the sound of air moving through the fans, tho'.
Follow the link for sounds bites from the following fans.
http://www.madshrimps.be/?action=getarticle&articID=936
(the GT1850 is in there too but not listed).
# 120mm Fans Tested
# ADDA AD1212HB-A71GL
# Delta AFB1212SHE
# Servo Nidec Gentle Typhoon DC1225C12B5AP-15
# Koolance Fan-12025MBK
# Koolance Fan-12025HBK
# Koolance Fan-12038HBK
# Panaflo FBA12G12M
# Panaflo (NMB MAT)FBA12G12U
# Sanyo Denki San Ace 109R1212H1011
# Scythe Kama-Flex S1225FDB12M
# Scythe Kama-Flex S1225FDB12H
# Scythe S-Flex SFF21E
# Scythe S-Flex SFF21F
# Scythe S-Flex SFF21G
# Scythe Slip Stream SY1225LS 12SH
# Scythe Ultra Kaze 1000 DFS123812H-1000
# Scythe Ultra Kaze 3000 DFS123812H-3000
# Nanoxia FX12 2000
# Noise Blocker XL-1
# Noise Blocker XL-2
# Noise Blocker XLP
# Noise Blocker M12 S2
# Noise Blocker M12 S3 HS
# Silver Stone (Everflow) R121225BU
# Thermaltake TT-1225 (Thunderblade)
# Yate Loon D12SL12 Curved Blade
# Yate Loon D12SL12 Straight Blade
# Yate Loon D12SL12 LED version with Straight Blades
# Yate Loon D12SH12 Curved Blade
# Zalman ZF1225ASH
GELID Hydro Dynamic Bearing fans are good, quieter than scythe imho, cheaper too.
