Fan question...
husker4life
The case i have is poorly cooled and i was thinking of adding a 2nd 120mm fan for intake, problem is my hard drive cage is facing me when i open the case up, it seems to me it will block the airflow alot. Am i wasting my time or will it cool it down a decent amount. The fan i was thinking of getting is an antec 120mm fan with 79 cfm.
_________________________________________
Athlon 64 3000+@2.0ghz(stock)
Evga 6800GT 350/1000(stock)
Asus K8N-E deluxe nforce 3 250gb mobo
pc3200 ddr400 1024MB(2x512) XMS Corsair memory
80GB IDE Maxtor HD
Lite-on DVD/CD RW
Sound blaster audigy 2 zs
Antec SLK3700-BQE Case with 350W PSU
Windows XP SP1, directx 9.0c, Nvidia 67.02 forceware drivers, nforce 5.10 mobo drivers
3dmark03=10790
3dmark05=4433
Aquamark3=58919
If you look carefully at the dsign there, you will see that this is taken into consideration.
Put the 120mm antec fan in there, and it will cool your HDD and case better.
EDIT: I'm not sure if this well actually help, but taking out the extra HDD racks might be an idea too.
Take out any unnecessary trays you might have in there. My friend (also with a SLK3700BQE) put a 80mm fan on the other side of the hard drive bays (the side facing the motherboard) that helps pull in air from the front. Think of the Antec Sonata and you'll know what I'm talking about.
