Fan power cord long enough?
InorganicMatter
I am thinking of getting two of these fans and hooking them up to this fan controller. The only thing I am concerned about is wether or not the little 3-pin power cable on the fan will reach all the way to the controller. Will it? And if it does not, how can I extend the cable length without cluttering up my case?
Usually the fan controller comes with 3 pin extension cables that are usually long enough to get where you need them to go. The only other thing you may need is some flex sleeving to cover them up and make them neater in appearance for what cant be hidden.
If not, SVC.com had extensions for fairly reasonable last time I needed some.
