http://forums.anandtech.com/showthread.php?t=2281123
Above shows the possible fan placement on my case. I read a post where the fans were place and flowing to create positive pressure inside the case, thereby reducing dust build up.
If I'm running 4X140mm fans, A ,B & F will be intake, and my only outlet would be would be D. If later on I OC I'll get rid of the stock cpu cooler and utilize E for an outlet.
Is this a sound plan in your opinion? Any alternate suggestions are as always welcomed!
Thanks in advance!
PS: Any suggestions on a fairly quiet, sub-$12.00 140mm case fan with some decent airflow would be great! NCIX has some nice prices but they rape you on shipping so...
MK
Thanks in advance!
MK
