soulesschild
- Feb 18, 2007
Is it possible to put my 3 MCR320 Yateloons med speed onto one fan channel on the Scythe Kaze 5.25 Fan Controller? It says 1A max draw, the each yate loon is 0.3A. But would I be able to adjust the voltage accordingly? I ask because I plan to have 3 yates, 2x S-Flex, most likely 1 on each fan controller, and another empty fan control that might control my ATCS 840 front 230mm intake fan. But ideally I'd like to have the 3 yates on one knob and be able to run them undervolted and at medium voltage.
Do most people here prefer drawing cold air outside the case from the top vs exhausting hot air from the case out the top of the case?
I'd want to ideally exhaust the air out due to dust control issues, but I know it's probably not as great in performance vs drawing cold air in. Are there fan filters for rads?
