Fan options for big typhoon????
alphaqforever247
I hear there are better fans you can replace with the stock one on the big typhoon can someone link me or tell me which fan would be best for it. thanks??? aslo there ne way to have ur fan always spinning at max with out buying ne fan speed controller.
The stock fan is pretty good... There are fans by silverstone that push ALOT of air at 7v... Something like 65cfm (110cfm at 12v). They're 14$ on the egg, but I can't remember their model #.
As for running a fan at high all the time, WHY you'd want to do that is beyond me... But run the fan off a molex connector... The 12v (yellow and black) line.
