im apirate said:controller is the way t ogo. they are 7 bucks on new egg. or a 4 channel one is arounf 18. Lol 6500 RPM thats a but load. Id buy it off you what socket type are you using?
there is no way that your CPU temps are that low.Stefan said:It's running at 22 - 30 Celcius, at 6700 RPM.
Um... It's the stock CPU fan for a barton 3200+...
what are you using to get those numbers?im apirate said:actually they can be. mine are on full load up to 40 C. On idle 28-32 C
see the link above your last post.im apirate said:Im using a 15 dollar heatsink my proc was OEM. I jsut bought my Tornado today. What volatage should i set it at. anyone have mod site?
