Ok, fan noise is a big problem for modders, and I think we are missing something in efforts to reduce it. I dont know what, though. What, exactly, is causing the noise? Faster fans, blades spinning faster, the air restriction, what?
Plus, that dead zone right up under the fan. If you were to get a spacer and lift the fan up 1/2 to 1 inch from the heat sink, would it eliminate that dead zone and cut down on the noise of these highspeed fans?
Or any other bright ideas? How about some sort of noise canceling device in the tower to cover it....
