Fan Modding..
Bigshot
I thought this would be best section to put this in since it deals with case fans. I tried a search, but no luck.
Here is my question, How can I have my case fans have reverse rotation? I know the obvious answer will be turn the fan around, but I need in this applicaton for the fan to blow in the opposite direction from stock. Thanks
Nope, even if you got the motor to spin the other way, it wouldn't be very useful because most fans' blades are only made to work one way, and would be highly inefficient spinning the other way
