I am in the process of building a Windows Home Server.
The last component I need to get is a case.
Seing as Hard Disk Drives, are the key component of a WHS server, I decided to see what difference a fan would make on HDD temperatures.
All components are currently on an open bench setup:
What I did was unplug the fan you see on the above picture, and check the temperatures on the WHS Console.
Then what I did was plug the fan and let it run for 10min and take another screen shot.
I was blown away by the difference. 22C difference for the middle drive!!!!
This has got to make a huge difference in the MTBF of the drives.
Anyone know what the correct range of temps are for HDDs?
I want to make sure I get a case with enough cooling but also quiet, so I would like to strike a balance.
