Fan layout?
Trying out the google sketch program and figured I would ask if this fan layout looks good? Would you change any fan directions around?
The fan directions are fine, though if possible I would definitely put a 120mm in the front as an intake.
Not without cutting a bunch of metal and popping out rivets, which is why I haven't done it. Centurion C5
In that case, you can mount a 120mm intake in three unused 5.25" drive bays(if you have enough). Does wonders for airflow.
