kill4killin
- Jul 3, 2006
Ok, so here is my project (on top of the sound dampening one.
I recently cut out the grill for the rear exhaust fan on my computer and put in one of the less restricting ones from newegg. However, most fan holes are usually round...this one however was sort of an hexagon shape so its not the same shape as the fan and frankly it just looks bad from the outside of the case. I heard that you can get like window molding to go around the edge and that will round it out because it cant bend enough to fit the sharp corners so i was thinking i would do that. Does anyone know exactly what my friend was talking about wit that stuff, and if i can get it at walmart since ill be there getting my case foam anyway?
