fan header max amps?
cyclone3d
So I've got 2 fan that originally came from Dell computers... One is a Nidec Beta-V with a max amp rating of 2.3, and the other is a JMC/DATECH with a max amp rating of 2.0.
I would like them to be controlled by the bios.. but am kinda scared to hook them up to the onboard fan headers.
I wouldn't want to run them at full speed... maybe 10v-10.5v max.. so they wouldn't sound like hoover vacuum cleaners.
Oh.. the board I have is an Abit AN8-Ultra.
Most boards can push about 25w total (all headers) before blowing... Or about 5-10w per header... Those fans, at 12v should pull about 20w each... (2a x 12v) so do NOT use them on a header!
yeah.. I figured that they would pull too much from a header... argghhh.
2.0 amps!!!!??? are you sure because thats a 24 watt fan at 12 volts which is outrageous.
most fans are 0.2, 0.3 amps or so.
if it really is 2 amps it might burn out the motherboard controller chip for it. that can only take 500MA (0.5A) or so
if you put 2A fans on it it would either burn the fan controller chip or (hopefully) cause it to automatically cut out from thermal overload.
