Fan Header Limits, where to find?
Fetti
I got a AN7 MB and was wondering, where do you find information on the fan header volt/Amp limits? I searched the manual and Abit's web site, nadda.
I have a 92mm Delta that uses about 12.5w and 1.0A at full speed. I want to use the FanEQ control to automatically speed up and slow down my fan based on temps. I don't want to hook up the fan and blow my header though if it can't handle it.
Any help would be appreciated. Thanks.
Look in the manual? My ASUS had all the specs for the fan power right in the description of all the internal connectors.
Like I said, I checked the manual. No good. Only thing I found was the voltage. +12V, GND, RPM marking which pin was which but that was it. All it told me.
A really good rule of thumb, If a fan has the word "Delta" in it's description, it does not belong anywhere near a mobo header.
LOL, ok, thanks.
Guess I'll find a good fan bus, temp monitor that will do the same thing then.
