Santasballz
- Jan 10, 2005
besides looking cool, do they serve any purpose?
Santasballz said:are fan grills attached on the outside of the case or on the inside? or both?
Especialy if you have a metal one. Took a good chunk form my thumb once. It was an irregularly sized fan used for industrial purposes modded into my case...wasn't all that great of a fan anyways, once it bit me it had to go.kpedge said:They also keep fingers, paws, and other obstructions out of fan blades. This can be a big deal for some fans at certain speeds.
redhalo said:Especialy if you have a metal one. Took a good chunk form my thumb once. It was an irregularly sized fan used for industrial purposes modded into my case...wasn't all that great of a fan anyways, once it bit me it had to go.
