Fan Grill
wankelguy13b
Does any one know were to get a get a Fan grill that covers 2 or 3 fans at the same time? I've seen them before, but I can't find them.
Thanks, I've been looking for those for a while. I knew it was something to do with radiators. Thanks again
I was looking for those same grills but couldn't find them with the other fan grills on most sites until I learned they were for radiators. :)
Is there any reason why the radiator grills can't be used with a pair of 120mm fans though?
I can laser cut a custom one out of acrylic for ya. Give me a shout sometime.
There is some other retailer online that carries tons of these, not just the AC ones... cant remember the name right now...
Yeah the acrylic ones are pretty slick looking as well.
Just make sure when you are cutting your fan holes and drilling the mounting holes that you make the template first. =) Measure 2x, cut once.
