Fan for Vid Card
TheCommander
Should the extra fan I am putting on my vid card be blowing at the card or taking the hot air away from it? This is a temporary solution until I get a new HS/F. I'll be sticking the fan to the vid card's heatsink with eletrical tape. Does anyone know by chance if the eletrical tape will melt?
I also got some arctic silver (the white one) on the main part of the vid card and cleaned it the best I could but there is some still left over. Will this affect my card?
Probably best if the fan is blowing towards the video card.
The Arctic Silver does have some Capicitance values to it and will effect electronic components if there is enough of it. For a good home remedy you can use Zippo Lighter Fluid to clean it up. Put some on a paper towel and rub it off and all should be fine.
No... you're going to want to install the fan to blow hot air AWAY from the card. This is the way most, if not all, video cards have their fans installed.
most video card fans do just the opposite of what you are saying. they blow air onto the video card. go stick a peice of paper below the fan on your card, will find it sucks the paper.
I have NEVER seen that happen before. So I went and stuck a piece of paper underneath all of the cards I have (X850XT PE, 9800SE, Kyro II). They all blew the paper away from the card. Well, except for the X850XT PE, which has a separate vent that uses up a second slot, although it did blow the paper when I put it over that vent.
It makes sense. You typically don't put an intake fan over a chip.
Actually, more often than not, you do.
Now, a lot of today's fans blow air sideways across the card, (example: reference nVidia 6800GT cards, reference ATI X800XL designs) so they're not truly blowing "into" the GPU, they're either going into the case across the heatsink as in the case of the former examples, or out the back, as in the case of the Radeon X850XT/X1800XT
However, cards that don't do this generally blow directly onto the card's heatsink. Basic examples include
here and here . They've worked this way for generations and generations of cards, starting with the some of the earliest earliest of nVidia (TNT2 Ultra, Geforce) and ATI (Radeon). Aftermarket fans such as the ones from Zalman do the same thing. Almost no fans in existance suck the air off of the heatsink.
