which fan is best fot thermalright xp120 heatsink?
i want high performance low noise fan, and if it has blue leds it would be a plus.
i found this 120mm fan from thermaltake. from the listed specs its awesome; but i;m not sure if there is carch and it wont fit or so. the fan is;
Thermaltake DC-fan series Thunderblade 120mm led fan
Detail Specifications
P/N A1927 A1928 A1926 Max. Air Flow 78 CFM
A1929 A1973 Max. Air Pressure 2.97MM-H2O
Fan Dimension 120x120x25 mm Noise 21dBA
Rated Voltage 12V Bearing Type Sleeve
Started Voltage 6V Life Expectation 30,000 Hours
Rated Current 0.38A Connector 4 Pin
Power Input 4.56W Wire Length 770mm
FAN Speed 2000 ±10% RPM Weight 140g
any ideas?
any ideas?
