Fan for Thermalright SP-94
Villhaven
Right now I am thinking of throwing a 92mm Vantec Tornado on this but I don't know if I wan't something that noisy running all the time. I heard if you put them on a fan controller and turn them down to 3000rpm they run really quiet and still move alot of air. Just wondering what anyone would suggest here as I don't have any experience with this fan at all. So would you throw the tornado on there and use a fan controller to turn it down when not running full out or just use a different quieter fan? If fan controller which one would you use? Never ran one myself. Thanks alot for your imput.
thats what my friend does with his SLK-900 and it works very well.
get a vantec nexus fan controller.
Use a Thermaltake SmartFan2. The performance is very close to the Tornado at a much lower noise level, and it offers both thermal and manual control.
yeah, just to let you know, Tt SmartFanII's are great, but they've failed me before their expected lifetime before :\.
flip
Myself I have the sp-97 (same thing as yours just the amd version)
Im using a 92mm Panflo fan (Panaflo 92mm -BX *RPM* 'HIGH' 56.8cfm 35dba H1B Fan)
56.8cfm with only 35dba is pretty damn good, I can't even hear the thing over all my case fans ;)
V0ltage, I'm afraid you're mistaken. I have both, and I've done the tests. Like it or not, there's very, very little difference between the two.
Also, 80mm fans outperform 92mm fans on the SLK-900/SP-94/SP-97.
any articles out there comparing temp diffrence with all fan options?
Geeky1 said:
Not that I've seen... :( I've got one on my "to do" list, though...
Im suprised there is not an article examing this then..
Like comparing all fan options, while looking at airflow and dba.
so say get a 50cfm 92mm fan, and a 50cfm 80mm fan etc see how they stack etc.
I mean I understand the phyics of how they work better (if you get a proper spacer for directing a 92mm airflow they can do better then) but no site I have seen has examined this in depth.
Also to take into consideration is the fact of noise, sure if you want the best cooling you might not care about noise, but its a fine line. For example my 92 panaflo pushes 56.8cfm... at only 34dba (thats not to loud at all)
But for 80mm fans there are gaps and the noise level rasies along with it much more.
a 80mm Ultra panaflo fan that only pushs 46.9cmf makes 38dba of noise..
now a 80mm delta fan that can push far more 68cfm makes 48.5dba (very loud) but yes that would perform better to, but not worth it for the noise.
now if I was insane, or hard of hearing :rolleyes: I could get a tornado 84.1cfm, but 55.2 dBA (INSANE) :eek: Id lose my hearing with that going. while a 92mm tornado pushs 119cfm at 56.4dba (I feel this would probably perform better then the 80mm, just becuase of the larger ammouant of air it is pushing)
For a GREAT noise level and pushes a great amount of air, get the 92mm enermax fan w/ speed control, wonderful fan.
For about 1 - 2C less than that, go with the Thermaltake Smart Fan 92mm at SVC.com for the blue LED version, or get the Smart Fan 2 for the nasty orange. :(
The 117CFM 92mm Tornado honestly sounds like a blowdrier on highest level, smart fan is much quieter, but this fan will drop ur temps down another 1 - 2C.
If you get the Tornado, DEFINITELY get a fan controller, its a must if noise will ever be a problem for you.
thinking about going with that panaflow fan, can you plug it right into the mb where the old fan plugged in or does it need more power?
