Ok i wanna get MSI NEO2 PLAT , but the fan i want ( ZALAMAN 7000B CU) says it will fit but only when
( Compatible when not using ZM80(A/C/D)-HP together! )
If you mean the Zalman CNPS7000B, it will work with the MSI K8N Neo2. You just can't also use a Zalman heat pipe video card cooler too due to space limitations.
