fan filters
marskid2
for 5 80mm fans. i want to try to keep out dust, and cleaning the filters isnt a big deal.
do they work?
thanks
wow, thats a lot of fans, why not get just one 120mm fan? or yoru case doesn't fit one? Anyways, a filter is better than no filter at all but it will restrict air flow a little.
yeah, its quite a few, the fans all cost me a bundle.
if i could, i would get a 120mm, but i have a branded chieftec dragon. my cpu fan is 120mm though, its the zalman one :).
good to know, i think ill order some on newegg or frozencpu in a little bit
thanks again
I second that Tiny :D
Panty hose works a treat, just yoink some from girlfriend/missus/etc.
Shadow27
if your not afraid of modding you can fit 2x 120 mm fans in the front :p :D
also you can probably just barely squeeze 2x 92 mm exaust, im modding both real soon
2x 120 mm and 92 mm M1A panaflo's are gonna be sweet :D :cool:
on subject of filters, theres no real use to filtering imo.. i just clean out my case every 6 or so months or when temps are too high if you have your air flow balanced you should not have dust problems
www.svc.com has a decent selection of filters I believe. I am not famliar with that case but I doubt you actually have 5 intake fans so you probably don't need 5 filters. Filters are only needed on the intake fans, not exhaust. Unless you are really concerned about dust I would run without filters and just clean out the PC once in a while.
three of the fans are intake, (two in the front, and one in the side right next to gpu) and two are exhaust. (rear of case)
make a blow hole, it helps temps on that line of case a ton, also i use jab-tech for my cooling needs
