im not sure about the price on the second you posted but you should try svc's as their filters are cheaperOriginally posted by ApocalypZ
Well i have a couple more questions. Should i get aluminum fan filters?
like this:
http://www.newegg.com/app/viewProductDesc.asp?DEPA=0&sumit=Go&description=11-999-213&searchdepa=0
or get :
http://www.newegg.com/app/Showimage.asp?image=11-999-206-04.JPG
keep in mind that i am getting a coolmaster and it has two intake fans on the front and i will be replacing the ones it comes with and putting in blue led fans...
