Fan direction/temps help!
sc00ter
Ok, for Christmas I got an XP-90 with a Panaflo fan and some AS5 and a Centurion 5 case. I installed everything in the new case with the XP-90 and AS5, booted it up and checked my temps through the BIOS. The CPU is at ~33C idle OC'ed to 2.1 GHz. Should these drop once the AS5 boots in, or are these decent enough already?
Also, both my BIOS and SpeedFan are saying my NB temp is at ~50C. What's up with that? Thanks for any help! :)
NB seems a bit toasty whats your ambient temp in the room?
good airflow throught the case?.
My room temp is at about 20C, and my ambient is at ~26C. The airflow is pretty good I think. One 80mm intake and one 120mm intake as well as a 120mm exhuast. I'll try to get some pics up soon.
Edit: Here's a couple pictures:
