I'm considering purchasing this fan controller to regulate the speed at which each fan spins (it's been getting a bit loud lately
) http://www.svc.com/35drivbayvrf.html
Now I know that watts per channel is an important issue in getting one of these, but if I plan on using a dial to control:
1. Two 80mm LED fans
2. Two mid speed 80mm Sunon fans
3. One 80mm similar to the couple being controlled in #1.
Do you guys think I'll have enough watts per channel? Each fan is rated at ~2.0 watts...
I'm also considering one of these http://www.svc.com/vane3mucobl.html and although there may be many better fan controllers to fit a 5 1/4'' bays, I just want to put mine in a 3 1/2'' bay.
Thanks for looking
Thanks for looking
