Fan controllers. Should I have ordered this one?
CyByte
I ordered this case Silverstone Temjin 5 (SST-TJ05-BW)
and then I ordered this matching thermal controller
Silverstone Thermal Controller (SST-FP52-B) -Black Fits 5.25 Bay
http://www.sundialmicro.com/silverstone_computer_case_ssttj05bw_1704_356.html
It only checks 3 fans :(
The case stock that I ordered has 4 fans NOT including the processor.
This one will match and appears flat which is good because it will have to go behind the pannel with the drives. It says it auto does the fans.
I would like full control of them so I can have them slow when I don't need the cooling and extra noise and full speed while gaming!
The processor fan I've been told to hook it up to a moxel cable. Any fan controllers do that?
I have to find one that will fit behind a door on a case and hopefully 4 fans as a minum up to maybe 6?
