Fan controllers help
vietkangta
whats a good fan controller i can buy that is not expensive?
I was looking at the on from scythe that has the temperature numbers easily displayed on it to see the settings.
Is there any other fan controller that makes it easy to see what temp you'refans are running at?
The scythe controller does not show what temps your fans are running at, it shows their RPM and the temps from sensor probes that you place where ever you want. The controller has worked well for me, I would indeed buy it again.
