sunbeam rheobus
pros:
cheap
works with pretty high amp draws (20W per channel, 1.5A rated)
it's black
cons:
cheap
bright LEDs
if you have a case with a door, the brightness is negligible (they won't bleed through the side of my mini p180 case door)
i'm happy with this controller
I am changing out the stock fans in my Antec 1200, putting in Yate Loon Mediums. The goal is to quite it down a little. Should I also be looking for a fan controller, and if so which one would you suggest?
