Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Do you want to control the fans to make them adjustable to your needs or do you need to just quiet your fans down? If you only want to quiet them down AND you have 3 pin headers on your fans get the Zalman MULTI-CONNECTOR 1.
Zalman makes the MC1 available separately in another slick retail package. It typically sells for ~US$2.50.
