Fan controller recommendations? (CM 690 case)
KenG10
Hey guys, I am interested in taking control of my fans in my new i7 build. I own a wonderful Coolermaster CM 690 case and currently only using the stock fans. I have them hooked up to my motherboard headers. I am noticing some headers spin the fans at different speeds and so on so forth.
So, with that, I want to take control of my fans via a controller on my front panel. What are your recommendations for a nice controller to be used in a CM690 case? Also recommendations on fan makes/models and fan configuration in the case.
Thanks!
+1 for the zalman MFC1
I have both the MFC1 and MFC2 and I'm currently using the MFC1 for simplicity.
Speedfan won't work on your board? If the fans are spinning at different speeds on the headers then the bios can also control the fans.
The sunbeam rheobus is probably the best controller out there that is not speedfan or bios.
Sunbeam Rhebous for a cheap good controller. I just purchased one not long ago and wonder how I went years without(prob b/c older computers ran hotter and used more power)
Anyway Jabtech has them cheap $13, black or silver
http://www.jab-tech.com/Sunbeam-5-1-4-Rheobus-Kit-BLACK-pr-2530.html
I like this one. But, can you answer this... when you turn UP the fan speed, the LEDs go from red to blue? So, when I have them down at normal speeds, the LEDs will be red?
EDIT, never mind, Google had the answer. Thanks.
