I have a couple questions regarding silence in my case. I'm getting a CM 690 II and 3 Yate Loon lows and 2 Yate mediums to replace the stock fans. I'm replacing the side panel fan with a gentle typhoon to cool my 5850... and such.
What's the best fan controller to use I need something that's under 30$ that has great build quality. i would go ahead and order a Scythe, but the packaging and screws that came with the gentletyphoon were absolutely horrible and I would rather support another company.
On an unrelated note... how do I minimize vibration without breaking the bank? My gentletyphoon is quiet, but against the acrylic it emits a rather annoying humming sound. Any home-made mods, or should I buy the plastic screws for 4 bucks a pop?
Thanks guys! i'll also post pictures when the case gets in.
