Fan Controller Help
GnG
Ok well i am looking for a fan controller it has to be able to fit in the 3.5 inch bay. See i have 2 Vantec Tornados and i cant sleep with that noise. So to be able to turn them down to 7V would be nice. Ok but the big problem i am having is that all the bay controllers i can find have big nobs on them and it wont work because i have a door on the front and it wont shut with the fan controller in there. so i need to find something that will work in its place. So i found this one from SVC http://www.svc.com/fp206bk-22.html but i cant find any reviews on it or if it even controlls the speed of the fans or just monitors them. So if anyone has any ideas or knows if the one posted controls the fans as well as monitor them it would be great.
Thanks
svc.com said:
The 3.5” front panel can serve as clock, fan speed controller, CPU/SYS-r/Sys-f temperature and Power/HD status indicators.
Seems like a pretty full featured controller.
