Fan Controller for TT Tsunami
-=WooDWorKeR420=-
Im looking into getting a fan controller to help reduce the noise of some of my fans, as well as control over their speeds.
Any recomendations on which type may be best, keeping in mind that I am limited due to the front door on the Tsunami Dream.
This is one that might work, although there isnt too much info in regards to performance or reviews.
http://www.frozencpu.com/bus-53.html
Any info would help.
THX
The Rheobus is great, Sunbeam makes a great one, etc.
But, I don't know if you are looking for a fan controller only, a multifunction panel, or something intelligent. I just picked up a VL System LIS 2 for my new computer I'm doing. It basically just looks like a VFD screen only. Thats all you see from the front. (similar to a cash register customer display) All your fans plug into the back, and it has intelligent control based on your system temperatures. For example, you can have your fans run at 50% speed, then once your cpu/case temp exceeds a set temperature, then your fans can kick up to 80% or whatever else you specify. In addition, the thing will display all your temps, fan speeds, ram usage, cpu speed/usage, new email alerts, and so on. I can't wait to get it hooked up and in use.
http://www.frozencpu.com/search.htm...v_session_id=iELki7p8&mv_searchspec=VL+System
Noni said:
I have heard great things about the Rheobus, but the only hitch with those controllers is that the knobs may interfere with the aluminum door on the Tsunami case, and may prevent it from closing. But i would have to check that out for sure.
I really do like these units, while i have had a hard time finding reviews or feedback on them they do seem like a great "all in 1" alternative, although the price might be a bit steep for me... :(
Haha those ones with a remote crack me up. Do you really need to wirelessly control your fan speeds? :D
lol.. I was wondering the same.. but I think they are for media center PC's. :p
the vantecs don't fit with the tsunami door closed unless you mount it 3/8" recessed into the case which looks retarded.
As was my initial thought. The door really does make a big impact on the choices available.
Any others? Keep em comin!
