Gilbert_pwns
- Nov 13, 2010
I have my 7700k overclocked but it's the middle of summer in SoCal so temps get up there if under load,
I previously had the problem of being stuck with 3 pin fans that I couldn't control. My mobo from Asus apparently only runs 3 pin fans at 100 percent so thats a no go. I've been using the voltage limiters that came with the corsair 140mm static pressure to cool the radiator but as I have said it's hot right now and need them to speed up but not at 100 percent.
I was wondering if anyone knew of a good fan controller for 3 pin fans. I know there are a lot of front panel ones but I can't install those since my case doesn't support it. Any help would be appreciated.
