Fan Controller and Wiring Harness Question
Status
Not open for further replies.
clayton006
I'm looking at ways to make my top external radiator more easily detachable from the computer if I need to move it for some reason. I'm going to install some koolance quick disconnect fittings that should help me remove the radiator from the water lines.
For fan connectors....
I have 8x Corsair SP120-High Performance Fans. I read that they draw 0.18A a piece.
I'm using the KAZE Q-12 Fan Controller and so far it is doing well.
I would like to put in two of these: http://www.frozencpu.com/products/7...an_Wiring_Harness_-_3_Pin.html?tl=g47c251s635
My KAZE says max of 1A output per channel and I'd only be taking up 0.72 for two channels if I go with this solution. Do you think this would be okay to do?
If it's rated for 1A per channel, then 0.72A per channel shouldn't be a problem at all. Go for it.
Status
