Fan Controller 13+ fans
Excalibrax
Looking for a fan controller to support at least 12 fans. Mainly will be Gentle Typhoon AP-45
x8 on radiators, with an 80mm fan either Scythe or Gentle Typhoon, and 4 case fans on 800d,
I like the idea of being able to control the fans with my computer in Windows, Should I just daisy chain 4 fans each and put them on various fan ports on the motherboard, Since I will be watercooling they won't see much use. Or is there another solution out there I have not seen.
Is there a way to Split the power and the PWM for the fans? I'd be willing to rig it so the power for the fans came in one way If I could route the controling to unit. Something like Zalman does for the CPU fans with a split for power and the controller but a unit for multiple fans not just one line. Still would love control via computer instead of console.
