Fan Connecting Question
Alaska Wolf
Likely a lame one. I'm starting to place my components in my case and do some planning.
I have a Cooler Master 840 ATCS case and will have an Asus P6T6 Revolution MB tomorrow.
I removed the 3.5 adapter from the lowest 5.25 slot and have mounted my DVDRW there. I did this because I now have the ability to use one SATA cable from my PSU to power both HDD's and the DVDRW. Cleaner but any problems with power draw? The PSU is a Corsair TX-850. Any problem with the DVDRW being right over the front 240 fan?
Then the one that has flummoxed me for the past half hour.
I have three 240mm fans and one 120mm fan in this case. The Revolution only has connectors for three chassis fans. There is the 3-pin connector for the Power fan...
Which fan should be connected to that one? And if I CAN connect all four of these fans to the MB using a 3-pin connector will this MB control the speed of ALL the fans? Including the CPU's?
Cooler Master 840 ATCS, Asus P6T6 WS REVOLUTION Intel X58, Intel Core I7 920,Corsair TX-850 PSU, 6GB Corsair TR3X6G1600C8D DDR3, Sapphire 4870 1GB, WDWD3000GLFS Velociraptor 300 GB System HDD. 1TB WD1001FALS Storage HDD, Samsung SH-S223Q DVDRW
Nope. The PSU is a single-rail design, so all the power is coming from the same place anyway regardless of which connector you use.
Nope, doesn't matter.
It doesn't really matter which connector each fan is connected to. However, it isn't a great idea to run more than one fan off of a single connector, since you could end up overloading it. I suggest you leave one of the 240mm fans on a 3-pin to molex adapter, and have the other three plugged in. The 240mm fans should be pretty quiet anyway, so even at full speed you probably won't be able to hear them very much.
Thanks!!
Is there any reason not to connect the three 240mm fans via their 3-pin connectors to the fan headers listed as "chassis fan" (there are three of them) and the 120mm rear exhaust to the one called "power Fan"?
Will that work well?
These are the fan headers:
CPU fan with PWM control
Chassis fan1 with Q-fan control
Chassis fan2 with Q-fan control
Chassis fan3 with Q-fan control
PWR fan
Thanks!!
Oh, I misread your previous post. I thought you said there were only three 3-pin fan connectors altogether. You can connect whatever you like to the power fan connector. It doesn't really matter. The only one that should be used for a specific purpose is the CPU fan header.
