Fan configuration help
reaper7534!
Here's the hardware
I7 930
Evga x58 sli Mb
Gtx 1060 g1
P400 case
Water 3.0 250mm rgb
3x 120 mm riing fan
2x 120 mm sp120
This is my brothers setup and I'm trying to figure out best fan configuration
The case requires the radiator to be mounted in the front. It will be push/pull. Will I be OK having intake on the front and blowing the hot radiator heat back into the case ?
2x riing fans up top exhaust
1 riing back exhaust
2x sp120 front rad
2x riing back rad
All static pressure fans
We will over clock. Opinions ?
