- Apr 7, 2006
Right now my computer only has the single 120mm exhaust fan, the cpu fan, and the GPU fan.
Right now they are all running pretty high and does not have good airflow.
I have a 120mm, 92mm and 2x 80mm slots available to add fans.
This is a desktop style case: its a CM Elite 360
The pics on newegg have it standing up, but I have it laying on its side.
The system is a gigabyte 780g board with a 4050e, GTS250 and pci wifi card.
There are 2x 120mm: One is on the top of the case above the CPU, and one is on the Right of the case next to the CPU.
There are 2x 80mm that are above the backplate.
There is a 92mm on the left side that would be next to the GPU.
How should I configure them....ie which ones should exhaust and which should be intakes?
Is positive pressure or negative pressure better?
