evilnickwong
- Dec 11, 2003
Right now, I have two standard Tt 80mm fans that came with my case working as front intakes.
I'm using the foam material that came with new mobos as a filter material and it's great in keeping dust out, but obviously limits airflow to the point that my load CPU temp has increased from 48 to 56.
Anyway, I'm thinking of replacing both those fans with the Tt Smart Case Fan II. The CFM rating is definitely MUCH higher than these, but is it going to help alot or has the foam material already limited maximum airflow to a certain point that stronger fans won't help?
On another note, what's good to be used as a filter to keep all the dust out? I hate having dust accumulate in my case.
