I've got a rig that I'm building for my mom. It's using a Radeon Xpress 1100 motherboard with a Sempron processor (stock heatsink/fan). Graphics and sound are on-board so all it really had in the case is the DVD and hard drives. The case itself has no built-in fans and that makes me a little jittery, even if it'll never be overclocked. The case has no fan options for the front, but I can put either an 80mm on the side near the CPU or a 120mm on the back. The motherboard only has one plug for a fan that I can find so I cannot do both. Which would you guys recommend?
