charlesshoults
- Mar 18, 2008
I saw the Intel NAS device on newegg a couple weeks ago. I've been wanting to offload some of my data for a while and have played around with FreenAS, OpenFiler as well as setting up an Ubuntu Server box with just a basic NFS share. The Intel device looks like a pretty nice little deal but I wondered how the thing was set up, and what modifications could be made to it.
After doing much hunting, I discovered that Intel has a download file available for use in the event that the NAS suffers drive failure. A link is provided at the end of this post. It sounds as though the NAS boots from a DOM module connected to the first IDE channel. The software from Intel writes a bootable image to a USB thumb drive of 256MB or more. It then gives directions on how to get the NAS to boot from the thumb drive, and overwrite the DOM.
Wanting to test it out before spending $150 on a NAS, I took an old Dell GX270 and plugged in an 80GB hard drive to the first IDE channel, disconnected the optical drive and left the SATA drive attached. I had to tell the BIOS to boot from USB because after all, it's an old and dumb Dell with an extremely basic bios.
I give it a 30% chance of working, a 50% chance of refusing to install on hokey hardware, a 15% chance of installing but failing to boot and a 5% chance of burning something out.
On another Windows machine, I created a bootable image on a 512MB SD card, then booted the Dell from that image. It brought up a shamrock and said Slax loading please wait. After the installation finished, the computer automatically shuts off. I unplugged the USB stick and turned the computer back on. As this was a test and it still tries to boot to SATA, I had to press F12 and manually select Primary IDE Master. It then cycled through the linux sequence and stopped at a prompt.
I installed the Intel Entry Storage System software on a Windows machine and launched it. It brings up a few screens explaining how to bring the NAS online, then confirms that it was able to locate the device. However, it next brings up an error message stating that "The 'storage' storage device cannot currently be reached" and gives options of Ok and Delete. Selecting Delete goes through the process again. Clicking Ok, brings a more useful screen with a link for updating the device. After the update, it allows a login. The system is online and for the most part, working.
Because there is only one SATA drive in the Dell, the disks are forever listed in a Faulted state and most functions of the NAS are disabled. These functions include adding users accounts, upgrading firmware and lots of others. However, even getting this far has me extremely hopeful. I'm going to try the same process again on an XFX 630i-7150. It has four SATA ports on the board.
As far as I've gotten so far, I now give it a 60% chance of working and a 40% chance of remaining in a Faulted state after all four drives are attached.
In case you want to try this out yourself:
http://www.intel.com/support/motherboards/server/ss4200-e/sb/cs-029094.htm
